I sure hope you aren't basing your stability on 5 runs of IBT? I have had a LinX stress test with AVX crash after even 76 runs running with 7GB RAM in use. You should make sure your system can run 100 runs of LinX/IBT with the latest AVX linpack. Otherwise it doesn't prove your system is stable at all.
Still yet to have a crash, im happy.![]()
You might not be having any direct crashes but you are most likely having micro corruption which can screw your system up and potentially lead to full on system crashes. I would't risk it if I were you
That's a load of rubbish. I'm not risking anything, Intel Burn Test stresses it far more than the constant gaming i use it for. If its not crashing in my eyes its stable. I don't need to stress it any more than i have done imo. If others want to stress it for a couple of days non stop to feel theirs is stable so be it.![]()
It's not a load of rubbish, LinX uses a specific algorithm, a video game might use a comletely different algorithm and/or instruction set which although might not 'Load' the CPU as much , it could ask for completely different equations, take AI for example.
Just because it is able to pass 5 runs, which quite frankly I can do using 1.3V compared to 1.36V to run 100 runs does not mean it is stable. Any program can use 100% CPU power if it is written to do so. You seem to be missing the point that if your OC can pass 5 runs, but not 20 runs then that means it won't always calculate specific equations properly which will lead to system crashes or micro corruption. If on the otherhand your CPU can consistently calculate 100 runs then there is no fear of it missing any calculation.
Of course, making sure your CPU IS stable requires more voltage, but that's the price you pay for stability. It's up to you. I just find it annoying when people quote their systems as being 'stable' on these ridiculously low voltages, making me wonder why I can't achieve similar results which are stable. A system that can only pass 5 runs I know if I were to leave it video encoding or run some folding equations it would crash half way through. The point being, if a system crashes on ANY benchmark, even if it takes 3 days, then it is NOT stable.
Unless you are limited by heat, then I don't see the point running an 'unstable' OC with low voltage unless you are after epeen or whatever it's called. As long as you don't go over OCUKs limit of 1.38V you should be fine. I would rather have a hotter CPU which lives 8 years instead of 10 to know it's actually 100% stable.
Keep your knickers on sweat pea.![]()
I was perfectly fine until you quoted what I said as "a load of rubbish" when it quite clearly isn't. You use your PC for gaming, I use my PC for more than gaming, we prefer different levels of stability, lets leave it at that.
***OVERCLOCKING GUIDELINES***
- Do not exceed 1.425-1.450v core voltage, doing so could limit lifespan of the CPU
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher than 1.60v could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
Where did you get the information from? or are you taking the mick?
