- 3 Mar 2006
- Atcham, Shropshire
no it's a known issue with the game
Im getting a lot of green flickering in BF3please dont say my first and hopefully high end gpu is about to fail?
Also on my Battlelog, my stats are showing as 0 toi hit rank 11 last night.
You probably have old drivers installed, update them!
Jets are awesome against tanks I've decided, you dive at them, unleash all your pod rockets (if you have them), quickly switch to main guns and finish them off.
And people say jets are under powered
how do u fire pod rockets, i unlocked them
No, does it with me occasionally on 11.10 prev 3.
So are mine, probably a server issue.
Think they just did some maintenance on the stats server. I've logged into a game just now and have the correct rank/unlocks.
Come join our server if you're about.
http://battlelog.battlefield.com/bf...rCreation-co-uk-Bronken-Gaming-1-Conquest-64/
The stats engine is down. They should be fine when they return.
+1
Head up too 1000 altitude, hold backwards to slow down as much as possible, and just dominate any armour on the ground, it's deadly.
+1
People only say that because they are rubbish, and then blame the aircraft for their inadequacies. The aircraft don't need to change, crappy pilots need to change.
Make sure you have it equipped on your aircraft, before spawning go to the air tab and select it.
What?! You bitch about it being needed in the game, then when they rush to appease you and the many others than complained by actually adding it into the game you say they should have left it out
Can't bloody please some people![]()
