Battlefield 3 thread - Server details in opening post -
Status
Not open for further replies.
You probably have old drivers installed, update them!
Also on my Battlelog, my stats are showing as 0 to :confused: i hit rank 11 last night.
Jets are awesome against tanks I've decided, you dive at them, unleash all your pod rockets (if you have them), quickly switch to main guns and finish them off.
+1
Head up too 1000 altitude, hold backwards to slow down as much as possible, and just dominate any armour on the ground, it's deadly.
And people say jets are under powered
People only say that because they are rubbish, and then blame the aircraft for their inadequacies. The aircraft don't need to change, crappy pilots need to change.
how do u fire pod rockets, i unlocked them
Make sure you have it equipped on your aircraft, before spawning go to the air tab and select it.
+1
Get owned of any decent enemy pilots or mobile AA cannons, and it's not deadly on full HP tanks, you won't get a disable on a tank even if all 14 pods hit.
+1
I'm glad someone agrees with me. I felt I was a good jet pilot in BF2, but I'm better in BF3. I haven't spent a great dealof time in them, but when I do I seem to do well. As long as you get control, and remain in control of the skies, you can seriously rape.
A lot of pilots don't seem to realise that alternating between increases and decreases in throttle mean you can really turn quite sharply, usually giving you the upper hand on other jets. If you get your aim right you can take other jets down in a second, not just a disable, but a proper kill. I love it :D
What?! You bitch about it being needed in the game, then when they rush to appease you and the many others than complained by actually adding it into the game you say they should have left it out :confused:
Can't bloody please some people ;)
He's right though, the commo rose doesnt work so there's no point it being there!
BF3 keybindings....do yours work?
New thread, as adding it to any other BF3 thread would get lost.
Ok, so.....anyone else having issues with their keybings, mainly for multiplayer?
I find it far more clunky than the BC2 or even BF2 method.
I have
PGDWN = enter/exit vehicle
PGUP = interact
So why do i have to press PGUP, instead of PGDWN in game to enter/exit a vehicle? I have double-checked this and they are set as i want them.
Also, when flyng a jet using k/m. I've changed the 'invert' setting, but it makes no difference, the keys still react the same way (not inverted as i expect).
Also, why does it allow you to assign a command to a specified key even though it warns you that its already assigned? So it actually lets you assign the same key for more than one command? Crazy!!!
Unless i'm missing something here.
There's no end of bug/glitches in the SP mode, maybe the MP suffers too?
Anyone else experienced similar?
Great game though, first time online last night, thoroughly enjoyed it, although i did find it hard to get into a server; took ages, and only once in, most servers kicked me at the end of the round. :confused::mad:
Status
