As you said, nothing in the market in that category.
They seem to have got a minor spec bump, they now ship with an
i3-2367M rather than the i3-2357M.
Not sure what the big deal is, couldn't find a benchmark.
Also the AMD models seem to have vanished from the UK site. I wanted to go for a second AMD one for my brother, but I reckon I would be going for the i3 instead.
You can knock up the font size to allow for the relatively high res screen.
My travels in linux
Debian - Squeeze don't support the inbuilt wired network interface. It will support the Centrino 1000, but they're too puritanical to include these for you, so faf++
Ubuntu (All varients) - If you get a black screen on boot, disable the UEFI in the BIOS. Once you've done that, everything should pretty much work. That said, I miss gnome 2.x
Just found this... looks like an x130e is on its way...
http://www2.partnerinfo.lenovo.com/partners/us/resources/downloads/live/US_Channel_Update_101911.pdf
Booted fine off usb key. might have been a different F key.How did you install ubuntu on the x121e. I want to boot from a usb memory stick. But I cannot find the boot option when I press F10 at start up ??!! Any help is appreciated. I bought the x121e primarily to run ubuntu 10.10 and at the moment I am struggling to even get to the point of installation.
That's just a little annoying as I ordered mine with the 2357m last week and I'm still waiting for it to arrive.
MAybe they'll just upgrade my order (I doubt it though)
You're in for trouble with ubuntu 10.10 - wired network card drivers won't be in the kernel as far as i can remember. Also, you'll want to turn off UEFI to get it booting - otherwise I just got stuck at a black screen.
Well I managed to enable the F12 boot option and everything seems to be fine apart from the wifi as I have the broadcom chip (thinkpad a/b/g/n). So you reckon I wont be able to get even the Ethernet port running on ubuntu then. What about using ndiswrapper and the likes ?? Apart from that the boot was fine from the usb. I will install it and run ubuntu with UEFI turned off.
No idea on the broadcom wireless - I paid for the centrino (Which works easily. Should be an easy swap with a second hand part if you need)
Wired ethernet - Support was compiled into the kernel around april, so if you can get a kernel update you'll probably find it starts working. Of course, might be troublesome getting a kernel update without wired or wireless network!
11.10 should work out the box, but then you'd have unity, and crashing. Fedora also worked out the box, but then you'd have gnome 3.
Thanks a lot mate .
The reason I am using the Ububtu 10.10 is because it was packaged with the OSIAN environment and I need OSIAN to work on my dissertation. I really like the look of Fedora 15 especially when paired wit Fedora electonics lab.
ps: Did you install Ubuntu 10.10 after manual partitioning. I have heard that the Ubuntu installer tends to wipe out the EFI System Partition (ESP) -- normally the first partition on the hard disk. The ESP holds boot loaders, including one that's vital for Windows to boot. Any wat to work around this.
Yeh, think I said it wouldn't be a smooth ride when you said you wanted 10.10.
Ubuntu 10.10 went on a fresh SSD. I never like dual booting, you always end up wanting to swap. I tend to find the OS which best suits the device for the purpose (Eg Server -> Linux. Firewall -> BSD. Desktop which does games -> Windows 7) and leave it with that.
Yep, you did mention this. I think I will have put up with not having internet while using the x121e for linux then. Or better yet search for another solution. If I do find a solution, I'll let you. Cheerio![]()
Looking at the performance claims, it's going to be identical performance to a X121 (See the performance claim against a netbook), but with some additional ruggedness. Good for kids, but the build quality on the X121e is perfectly fine for me to take around with me. And frankly if i damage it's not cost the world. Long as i can recover my SSD!
Plus rugged will come at a price, financial and in terms of looks and size.
Until Ivy Bridge comes along, anyone with an X121E shouldn't be worrying about upgrades. And Ivy is only really going to help with battery life - which is already excellent.
I'll keep you posted when I get the updated processor one, but as Wishy said, it won't be a difference that you would be able to see.
I suppose that depends what you're doing. If it were say a second faster at processing an image file (what I'll be using it for) then that soon adds up. 60 images becomes a saving of a minute.
At a festival, I could probably process out around 600ish images a day, so based on a second that would be 10 minutes over the course of the day (enough time to grab a smoke and a coffee!). I can live with that, but it's still a little annoying that I missed the upgrade by a couple of days.
Looking at that x130e thing again, maybe it's just going to be the US version of the x121e (as they can still only get the x120e atm)? If that's the case, it'll be roughly the same. They may have to maintain different model numbers for the wireless licensing doodar they have to do?
x130e is more ruggedised, it says so on the PDF.
Also are there any 10% codes aroundd for the Lenovo site?
