- 10 Nov 2003
- Surrey, by the river
Thats bike number 3 sorted....now to think about a number 4![]()
What are 1 and 2? We need details dammit man!
AFAIK the highway code says that in built up areas you should opt for a steady light.
I'm not sure the reasoning, but its in The Road Vehicle Legislation Act of 1989:Any reason? My front light does both but I always opt for a flashing light as it's more noticeable. Steady lights can 'merge' with other vehicles' lights, especially to pedestrians' peripheral vision and driver's rear view mirror.
The Road Vehicle Lighting Regulations said:13.—(1) Save as provided in paragraph (2), no vehicle shall be fitted with a lamp which automatically emits a flashing light.
(2) Paragraph (1) does not apply in respect of–
(a)a direction indicator;
(b)a headlamp fitted to an emergency vehicle;
(c)a warning beacon or special warning lamp;
(d)a lamp or illuminated sign fitted to a vehicle used for police purposes;
(e)a green warning lamp used as an anti-lock brake indicator; or
(f)lamps forming part of a traffic sign.
Any good? Folks on Retro Bike seem to think they are a bargain.Could someone recommend a good (cheap) front flashing light please?
Been looking at the Knog frog but wasn't sure if there was something better out there. It's really just something to have on at dawn/dusk when my normal light isn't required and as a backup.
You're not really supposed to have a flashing front light.
).EH2009449 is the correct part - I have recently purchased two of them for my Mars 3.0, so I know that it's the right one. I also have two mounts for the previous version of the Mars 3.0 (http://www.chainreactioncycles.com/Models.aspx?ModelID=19048) in case anybody wants them (and I can find them).
I love the awesome photoshop skillz from MadisonIt appears madison stock it as a spare and it's in stock.
Mars 1.0 / 3.0 / 4.0 seat post clamp
Code: EH2009449
Glad to hear it.I'll take a pic of mine tonight iirc, so you can see just how effective they are.
My wife bought me a Garmin Cervelo Team Jersey for our Wedding Anniversary and it doesn't fit!![]()
[DOD]Asprilla;20529337 said:Made by Castelli so it's italian sizing. You need to go one or two sized up.
It seems to be a tighter cut then other jerseys I have of the same size. Going to have to return it and see if they can exchange it...*sniff*
?I'd be interested to see that if you get the chance. The only thing that's putting me off is the price, but on the other hand it's better at putting out peripheral light that any torch.
. Will try again tonight.All of my bibs are Castelli, but this was my first jersey so difficult to gauge. I don't wish the jersey was bigger, I wish I was thinner!![]()
They're my favourite manufacturer by far though. The quality is superb.
Slipping into Castelli gear is like having your suit fitted by a proper old school Italian tailor, rather than a Marks and Spencer fitting room attendant. You get your inside leg felt, and feel more embarrased at the fact that you liked the smoothness of his touch, than you do the fact that some old suave gentleman got too close with his tape measure.
