The Extreme4 is a popular board. That and the MSI I showed you have almost identical features:
MSI GD55
AS Rock Extreme4
Either of them would be awesome in your rig. I'll let you decide. There isn't a bad choice.
Which would you say is the better board out of these bad boys????? I'm thinking Asrock but then maybe the UD5 ?? Help please!
dont forget about the no VAT offer going for the MSII'll take a look tonight then..maybe even place the order :O
MSI GD55
AS Rock Extreme4
What board you running now Chippy?chippy08 said:The Extreme4 is a popular board but over hyped as i have it but will only clock my cpu to 4.4 where as the Asus overclocked my cpu to 4.9 so me thinks the Asus is better.
well I guess more initiates to the 'asrock headach club'
oh and just hope the board doesn't arrive with any bent pins, otherwise you'll be £170 out of pocket(£136 to buy plus the cost of returning it to ocuk and the cost of the rejected rma), plus if my recent experience is anything to go by the chance of being called a liar if you call up to argue that you didn't cause the bent pin/s(I'm suprised other companies haven't used such cs techniques). you will than have to resort to sending it to asrock(if you want to have the board fixed) which will be another £35 so over £200 spent on a board that shouldn't cost more than £140. I had this on the extreme7 which thus far has cost me £245 and will end up costing me £280/£290 if I send to asrock, wish I hadn't been sucked into the special pre-order price £210(will end up costing me similar to the asus maximus iv extreme/gigabyte g1 sniper 2).
and unless I'm mistaken the ud5 was £150 NOT £190 just the other day, guess the 'was £150' wouldn't make it look as good a deal![]()
Well that makes me feel reassured! I may cancel my order now!
Yes, I almost did order on UD5, but I wasn't to sure about the CPU pin so I cancelled my order.![]()
What's the correct route to cancel it's it webnote?
Just ring the sales line first thing tomorrow![]()
OK cheers, I think I'll just change the Asrock to another one. Now do I change to the UD5 or the Asus?????![]()
