At this point, you can get the i3 one from lenovo at £350 with the 10% reduction - including free delvery. Going for the AMD one would be rather silly.
Yes you're quite right... thanks for pointing it out.
However, to complicate things further, I have just come across the the Lenovo IdeaPad S205 which can be had for £280...
* Processor: AMD Dual-Core E350 1.60 GHz
* Operating System: Genuine Windows 7 Home Premium 64 bit
* Display: 11.6 inch WXGA high-definition LED backlight, 16:9 widescreen (1366 x 768)
* Graphics: AMD Radeon HD 6310M
* Memory: 2 GB DDR3 DRAM 1066 MHz (8 GB max.)
* Hard Drive: 250 GB 5400 rpm SATA
* Sound: Stereo speakers with sound enhancement
* Integrated Communications: 3 x USB 2.0, 6-in-1 card reader, headphones, mic, VGA, HDMI, Bluetooth
* Camera: 1.3 MP integrated web camera
* Weight: 1.48 Kg
* Dimensions (WxDxH): 290 x 193 x 18-26.3 mm
* Battery: 6 cell
Obviously it wouldn't compare with the Intel ThinkPad X121e, but it does compare favourably with a similarly priced netbook. I guess I just need to decide whether to go for price or performance... simple right?!
The Intel one is pretty much 100% faster. The AMD is still a lot better than an Atom-powered netbook, but the i3 is properly powerful.
I'll have a look for a comparison, but I'd still appreciate it if anyone could provide a relevant link.
I just got an i3 with the lowest cost ram and HDD options and some basic additional extras e.g. 2GB, 320GB, 6 cell battery, fingerprint reader, camera, intel wifi etc for £362 (10% off plus free delivery), I am well chuffed!
Thanks for sharing. I think if I do choose to go down the performance route then I'll do something similar.
