The games available on the iPhone were much MUCH better, there is no comparison really I was shocked at the lack of games on Android, but the S2 with emulators + ps3 pad is imo the best option. For some games you really need a physical pad, and the ps3 pad is as good as they come, and you basically have a SNES, Mega Drive, N64 and PS1 in your pocket!![]()
http://forum.xda-developers.com/showthread.php?t=1347753
Seems like this maybe the first place to see the SGS2 with ICS.
They have the screen showing an error message now.
Don't forget the Gameboy for Pokemon awesomeness. Completed Pokemon Red a month or so back
Oh, and as for the battery thing before, I've just been out for 1.5 hours with music on the whole time apart from a 5 min call, and sent 7 texts and received 7 texts and used 5% battery.
I read your post, Both your WIFI & Data get cut off though. Only the WIFI does on mine, I can still use data network as well as receive calls & texts. Also mine is the official cable not 3rd party.
Did you manage to fix it though?
My journey to work takes 45 minutes, with music on the whole time I lose exactly 3% everyday. Not that unbelievable to be honest.
Yeah it's about that. About 3 mins to transfer 1gb. if you want transfer speeds then take the memory card out of the phone and put it in your pc.
I think I've had battery life like the two mentioned, from the regular battery. Each morning was at least an hour of podcasts, half of that from the speaker. I would quit often only use 4% in this time.
