Caporegime
- 9 Mar 2006
- Surrey
Some quests don't hold your hand, you need to work it out. I can give you a hint for that one if you want.
No, all it says is
"Do you know all three Words for five Shouts? Then you’ll need to slay and absorb the souls of fifteen dragons to fully unlock them all. That’s a tall order, so consider carefully which Shouts you really need, and spend your Dragon Souls wisely. For example, the Aura Whisper Shout (which tracks the movement of a foe) is great for an assassin, but is less useful for a berserker who simply charges into the fray."
I suppose when you think about it, it is a tall order. Most of the powers that I've come across so far are quite useless without the third word. And in 50 hours of play, I've only slayed about 6 dragons.
Lol this is why guides are stupid, I've got so many spare souls it's ridiculous!!
No, all it says is
How many shout words (and completed shouts) have you got?
I've easily got enough souls to max all 8 and have enough left over for 3 more maxed!!
[SKR]Phoenix;20630700 said:It's awsome! I also reckon worth quite a bit, even second hand. People will go nuts for these on the bay of E.
If you use your shouts in towns (pointing away from people) a courier will appear and give you a letter from a friend with a new location or dungeon (map auto-updates) which will have a word of power wall.
The guide is absolutely amazing. So helpful, even if it has spoilers in it. Definitely one of the best guide books I've ever seen.
My local store had 11 of them in last night. I'm quite tempted to pop in and buy another to sell on the bay if they're going for that much!
If you look at eBay prices the hard back is going for 40-50 and the paper back for 30
