Very tempted, but I didn't think it was recommended to clone a HDD onto a SSD because of all the fancy stuff that needs to be done?
Although iv ordered this is something i thought too? Like you were best to do fresh install to allign the drive or something?
I would be happy if this is not the case and will work fine.
In theory you can close the HDD to the SSD but I wouldnt purely because of the modes involced at bios level.
A HDD is usually in IDE mode and an SSD like this performs best in ACHI mode.. as such a clobe will more than likely not work correctly or maybe not even at all.
Third time's a charm![]()
I hope these don't have the "sandforce-2281" problems.
Ok so if I did a fresh install of windows I would then use the software to copy it all across? Basically like doing a system restore it will turn the new install of windows into exactly how the old one was?
Also just to confirm I will be running it on a sata2 port so a normal sata2 cable will be fine?
Theres no such thing as sata II, or III cables, its a marketting gimmick.
