*** The Elder Scrolls 5 - Skyrim Official Thread ***
In my game the dumb bint ran in to one of those swinging blades traps that you come across in some of the ruins, so I just took my **** back and left her :p
My Lydia got killed by a Draugr Deathlord :( so i had to kill it. Then when i went to marry my new companion mjoll the lioness, Lydia's dead corpse spawned in the chapel prompting my bride to be to disown me :D
Just purchased a 4gb Slim. Do you guys play from the Disk or are you installing it. Not sure if i should purchase a HD or not. Thanks. Or can you install games on usb sticks these dayS?
There are texture issues if you install to the HDD. Either run from disc or install to a usb stick. You will need an 8gb one and can use a max of 16gb per stick..
Cheers Moogleys. Do i need to do anything to the USB stick or can i just get any fast 16gb usb stick?
Also, will i see any performace increases running from the USB or was it optimized for running via the disk.
Thanks in advance.
The apprentice at work said his mate has claimed to 'complete 100%' twice already lol.
I am going to have a good old session on it in a moment, prob won't stop until tomorrow morning!
Thanks in advance.
I believe any USB stick will work. Just connect it and the Xbox will format it for you.
I noticed faster loading times and smoother gameplay when installed to USB. :)
Thanks in advance.
Anyone will work. If you go to memory and select the usb stick it will give an option to format for use with the xbox 360. You will loose a fair chunk to system use.
It loads a bit quicker from usb rather than the disc but more importantly it makes it silent with no disc spinning noise when playing.
Finding this a bit tricky at the moment. About level 34, playing a stealth/bow character. Have tried to level up one handed skill using daggers, but i'm finding now if I can't one shot someone or take them down from range, i'm destroyed in about 4 hits or a couple of spells.
Not sure if it's supposed to be like this or my light armor skill isn't that great but it's quite annoying! Definitely feeling the need to play a tough character who can take on a few enemies at once.
Holliday, I'm going to take that route for my third character. Haven't tried stealth/bow yet but I was planning on using Illusion magic for when the situation is too hot for the bow. Hopefully calm the enemies or frenzy them into attacking each other, for example. Have you tried using any magic?
One of the most annoying things about this game is the sheer amount of stuff to do! I wander around on the way to completing a quest, find myself gaining another 6 quests, start to complete them, gain another 5.
Tough life in Skyrim :p
