Think I'm going to order one of these and a new psu, just trying to find out if i need any adapters to run two dvi monitors of the one card.
Just placed my order on this a lot of thought into if i should wait for the new ones, or go down the cheaper gtx560ti but as my last card lasted me 3 years hoping this will do the same.
I'm not much over the minimum required PSU, is this likely to cause any issues when overclocking it a little?
If i remember correctly my psu is a coolermaster or Thermaletake 550w
And going forwards if i was to Crossfire these would i need 1kw PSU? As this is at the top of my budget for a graphics card i cant see a 7950/7970 being around this price for quite some time. Poor old 8800gtx is getting hammered on bf3 when people let of smoke grenades and im on low settings![]()
Just placed my order on thisa lot of thought into if i should wait for the new ones, or go down the cheaper gtx560ti but as my last card lasted me 3 years hoping this will do the same.
if its the same as the 6970 lightning then its 310mm
A FOOT OF GRAPHICS CARD!!?!?!![]()
no adapters needed for just 2 monitors, its if you want to run 3 monitors in eyefinity that you have to have 1 connected to the displayports of the card thus if you don't have a monitor with displayport you need an adapter.
Smart
hope your case can fit it as its a loonnngggggggg card.
i have a Thermaltake VA9003BWS Kandalf Full Tower (got this full title from when i ordered from here back in march 07 for £118, might have to move my drive bays a little to get it to fit. all else fails i'll get the angle grinder out and make some adjustments! haha
no need for 1kw for xfire, 750/850w is what you need. if you were planning on tri/quad fire then you'd want 1kw. check what the exact make/model of your current psu is.
if you have the budget then you may as well get http://www.overclockers.co.uk/showproduct.php?prodid=CA-005-XF&groupid=701&catid=123&subcat= if you don't mind its not modular
I also ordered this to go with itshould have the power now without worrying
oh and what case do you have? the graphics card is 310mm long so you need to check your case can handle it.
Gibbo would this card bottleneck my system,quad [email protected] with 4 gig ram![]()
im on q6600 4gb ram
(although im sure they'll sort this out for me )That is CLEARLY not a Twin FrozR III cooler card....the one i recieved is this one : http://dragonsgaming.wordpress.com/2011/05/27/msi-r6970-2pm2d2gd5/
