** ALL HAIL THE NEW HEAVEN KING - ATI 7970 3GB!! (TRI-FIRE TESTED)**
So single one OC'd is pretty much same performance as GTX470 SLI @ 800MHz... which is very decent performance but I've been enjoying it for over a year and only paid £300 for it :D
Yes it is decent result, single 7970@1125MHZ- 1830, price unknown(anywhere between £400-£550).
But my 6950>70 Crossfire@1GHz- 2237 @£400 that Iv'e had for nearly 1 year, I know what I'm keeping(although I have said that before)!:D
Meh - only 1021 points more than my 5850 in single card config - not interested :p
Subjectively how loud is the ref cooler versus a twin frozr II? I run mine at 45% under load (30% idle). Be interested in how well the cooler can cope with reduced fan speeds as well - I hate my machine sounding like a hovercraft at launch.
Have you ran any more? 3dmark11, vantage?
one benchmark :/ common you slackers.
I'm intrested in real world performance over a 580 3gb and 3gbsli and weather or not they run without crashes on bf3 and does it look as good as last time I went ati the games never looked as good, also I want no slowdown when in smoke on bf3
However for me they need to be 10% faster than the 580s or be under £300 as 580s are old tech now and will be replaced very soon and by something that should be 10% faster minimum
And why not against 580 3gb in same machine
92c is massive my 480s on air overclocked don't hit 92 and that's in an 800d
They're also slower, louder and I'm going to assume there's only 2 of them rather than three?
I don't think it's really comparable :)
There renound for being hot, people slate them because of how hot they are so if there hotter than 480s it's very relevant plus I'm talking hours of battlefield not a 10 min bench so 90 in 10 mins is massively hot
Are you even intrested in buying one of these cards?
I use 2560x1600 for gaming.
And me so these benches are needed
But can it play Crysis? :p
j/k
I'd like to see benchmarks both in 1920x1080 and 2560x1600 res with:
Crysis 1 and 2 (DX11 texture patch)
Metro 2033
BF3
Witcher 2
Skyrim
Pretty please, with sugar on top.:D
lol at heaven people want to see bf3 benchmarks and price basically as everything else can be done on every other card quite easily
Who said Minimums are nice :confused:
Minimum FPS are marginally better with 2 cards and worse with 3 !
Not very good really !
The minimums aren't really relevant with the Heaven benchmark.
They only occur in the first few frames as the benchmark starts.
The frame rate for the remaing 99.99% of the benchmark will be much higher.
Gibbo will you be doing the same kind of benchmarks for the 7950? I really want to see how one of them stacks up against a GTX580 at 1080P.
As he said - the minimum fps tells no real story with Heaven (or most benchmarks) unless you know what percentage of the time the framerate was below 30.
I can run the heaven benchmark 10x in a row and get anything from 7fps to 58fps minimum with a GTX470 SLI setup.
Single card BF3 benchmark on Caspian border and Gulf of Oman 1920x1080 and you might sell some more of these.... at least 1 :O
So you're comparing two cards with louder coolers, running a less intensive game to three running a benchmark.
No, so?
The reason the 2560 res bench's are important as most mutli gpu of this gen will struggle there...
1080p is easy compared and will max any game out there with 6950's at that res but not so to speak at 2560
And these are the people who will be buying this card in a multi gpu set up....
Unless your like one guy i saw on youtube with 4x 3gb 580's running it on a 1080 screen ..... :o
Anyways any news on waterblocks??
Oh and ps BF3 benchmarks pleaseeeeeee
