in this bench my cards dont hit 60 id be intrested to hear what these cards hit in single crossfire running this bench
so your only in here to troll then?
Impressive, what is the tool he is using to over clock card as be good to see how far they can go on stock cooler.![]()
he will be using cascade dice or ln2 with massive volt mods
The minimums aren't really relevant with the Heaven benchmark.
They only occur in the first few frames as the benchmark starts.
The frame rate for the remaing 99.99% of the benchmark will be much higher.
I understand you, but from a technical angle min is min, same test for all setups !
In that case the former leader in the Heaven benchmark thread had a really crap setup.
Quad GTX 580, a score of 4406 and a minimum of 16.6FPS.
I think the benchmark runs before all the graphical data has been moved.
BFBC2 takes 2 times as long to load a map when in Quadfire than when i run Dual GPU.
