I use Go SMS Pro instead of the standard sms app (samsung galaxy s2 built in), and it used to kill itself when I pressed the back button to exit (it no longer appeared in running apps). However following an update it no longer shuts down, and so just runs continuously unless I manually kill it.
Should I worry about killing it each time I exit it? I have read conflicting opinions on whether killing tasks manually is a good idea or not. (I also manually kill the internet app (built in), each time I finish using it)
. Do what I said above and you will be able to log into the site
