- 9 Dec 2009
- Bristol
Non-regulated power supplies like those you see that come with routers tend to provide a higher voltage until you load it up with something. I have an old Netgear 12v@1A which I currently use on my CMoy and that puts out around 18v at little or no load.
I'm assuming that a Nixie clock has a more substantial power draw than a Cmoy so you should be ok.
Ahh right, should be ok then voltage wise. The Nixie clock instructions say the power supply must be at least 250 mA. My Netgear 12v adaptor is 135mA. Will this be ok?
