i dont like the Pontiac or the spec racer, think ill stick with the mx5 till i can enter the skip barber series...
If you don't like the Spec racer you may not like the skippy either, both have quite similar handling traits...
Skippy as mentioned is probably quite similar to the spec racer so maybe not for you.
Mustang is kinda good fun, been a while since I drove it but it understeered a far bit but you could provoke it into nice controllable oversteer. I prefer a 'pointy' front end so not really for me but can be good to drive occasionally.
Jetta TDI - dog, avoid, horrible, nasty. Well I guess a simpler way of putting that could be FWD and Diesel, in a race car, seriously? Hateful hateful thing![]()
This game is owning my *** but I love it.
Well worth the subs for the joy it brings
Have requested an rF2 refund too![]()
I'm getting better times each time I drive the mx5, really loving this game.
shame there's some idiots that still ram you off for no reason but that don't happen in every race so I think the safety rating is a good thing as its some of if not the best multiplayer racing I've played...
Really gonna have a good go at this today, first time using a decent wheel ever and using a proper sim so it feels so strange. Used to need for speed where you can just run full speed round corners :L
Really good feedback from the car on this
What settings do folk use for the mx5s with a g27? Could do with some pointers on it![]()
), if the car has >900 degrees rotation then it will go non-linear near the end of the wheels travel, which again you probably won't get to during normal driving.I take it you're not taking part in the BTDC then![]()
Excellent, new converts \o/
G27 settings should be the same as the G25, and off the top of my head,
In the profiler set:
Strength - 100-105%
Spring and Damper to 0%
Centering spring checked but at 0% (although I use 20-25% as personal preference)
Rotation to 900 degrees,
Then in sim calibrate normally and set the FFB level to taste, I have mine quite low at around the 8-12 mark, but it depends on car and taste.
The sim will sort out the rotation beyond that, so cars <900 degrees rotation will be 1:1 throughout the entire range (it will keep turning which does irritate some people but I rarely get to that much lock whilst racing), if the car has >900 degrees rotation then it will go non-linear near the end of the wheels travel, which again you probably won't get to during normal driving.
yeah mine setting were more or less the same as skills bar the rotation which I've got at 270..
they work well on most games I play...
ok sound I'll put it on 900 and re calibrate my wheel on iracing see if I like it.
I'll change it back to 270 for rf2 tho...
