The latter wont care, in fact he might like the fact that he no longer has to worry about children, might even make it worse.
the fact he will have hardly any testosterone so little libido might stop him though.
The thing is there was a guy I saw in an interview on TV here saying that he acknowledged his problem, wanted to change but couldn't as he always had the niggling urge in the back of his head which held him back before he underwent treatment (can't remeber which type, surgical or chemical, probably the latter as it's more common).The difference between a man who wants them off and one that probably doesn't is that, the former has acknowledged his problem and wants deal with, likely meaning that he wont commit any further offensives.
Why not put all the rapists on an island, then they can rape eachother all day? problem solved lol
Why? whats so wrong with what I say?
and what do you do with the thousands of road workers you just made unemployed?
I think it is a good idea. Personally I think rapists and the like should be hung. Not as a deterrent, but because it is the only way you can be sure, as in 100.00000% sure they will never offend again. Plus it saves on tax money.
I say either cut it off, or make it too small for them to use![]()
No, offenders should not be castrated.
Quickly repeat myself here. Castration does not invole removing the penis it involes removing the testicles..
I just said lob it off
Put you on an island, you can troll yourself all day.
If you don't know by now it is a mute point trying to explain.
And your reason for this stopping someone from raping someone would be...?
Sheffield has two universities, you must have act as the counter balance to the weight of available learning
How could you physically rape someone if you no longer have nothing down there.
Use something other than a penis, obviously.
