They enjoyed it, if they rated it by your criteria, it doesn't matter what they personally think.
*sighs*
*sighs*
No, people rate quality products
Rather than saying sigh and adding nothing, why don't you explain your point of view.
Under your criteria bad films will be rated badly, regardless of enjoyment. So how do all the enjoyable films that are known to be "bad" con air, Armageddon, air force one and a million and one others all get over 6/10. Under your criteria that just wouldnt happen.
, you fail to comprehend it.
then you have explained it well enough.
Woo more selective quoting.
So I have understood you all along, now try applying that to the ratings on imdb and it just doesn't work. Notoriously bad films are still highly rated. Use other examples of you don't think mine fit.snip
Tyrannosaur - 8/10
a slice of life i hope never comes my way
