Watercooled Case Gallery
New case = more room = dual rad = less noise = cooler = win!
Still work in progress, need to finish off cable tidying and a custom window but overall not bad. Case is a Fractal design XL, had to remove the optical bays to fit the radiator which isn't really an issue for me as I use a portable DVD drive or download everything anyway.
I cant wait til this case is released im gonna try my first water cool with it! Really like the look of JamesM's white tubing in the post a little further up! This case looks really well designed mainly for watercooling top draw NZXT
Looks really good.
After all the hassle I had with compression fittings I think when I get round to tidying things up i'm just going to go with 1/2 barbs and some angled connectors haha.
Finally have my PC sorted and i decided to post it on here in all its glory...
I was thinking about replacing the red tubes with Green ones with blue anti kink coils and UV Cathodes what do you guys think? im on the fence at the moment. Is it worth bleeding the whole system to change it? So help would be appreciated!
how come you've got an anti kink thing on a practically straight bit of tube?
I'd sort the routing out and lose that altogether as the rest looks really good.
I like the look of the kink coil on the white, i no what you mean with the tubing. Didn't really no how to route without it being in the way, also when my block comes for the 7970 how should i route it, cpu->gpu->res but how, where to put the tubing?
matt100 that looks really good, needs better photos though, like you said. The first pic you posted earlier in the thread showed the colours better imo, the braided cables look sick.
I can't photograph for **** I've only got mobiles but an iPhone 4S and a Nokia Lumia ought to do better than what i produce.
not really the devices but better lighting would help. both have decent cameras and if you arnt happy with em tons of guide tutorials on how to use either one better
