- 23 Dec 2009
- RG8 9
Tried and failed to hit 4Ghz. Had PC shutdown 3 times and gave up. Going to have to bump it slowly slowly.
I want to get my 965 to 4Ghz. It is verry happy at 3.75 @ 1.375 volts which I have achieved by just upping the CPU Bus/ Peg Freq to 220Mhz.
Should I upp the voltage to 1.4 and up the frequncy till it hits 4? C3 revision with a good cooler.![]()
24/7 clock 4.1GHz 1.45V 2.8GHz Cpu-NB 1.35v
4.2ghz on only 1.40vlts.!!!
Unless you struck gold with your particular CPU, the vast majority of Phenom II Quads need more vlts than that once you go past 3.8Ghz.
May well be stable in gaming at 1.4vlts because i doubt any game out there will stress the CPU as much as a burn test will, so that is when the instability is showing itself.
Thats funny.... I was able to hit 4.0Ghz on <stock volts.
Are you sure its not the ram causing you to crash?
WTF!!!
My temps are twice yours at stock :0
