it's just a new transition effect. when moving between home screens they rotate backwards slightly. its nothing to get excited about really
so whats not working on it ?
I havent found anything. the first impressions thread over at xda says this:
• As always the first thing I did was checking if the phone calls were great or not, and as usual there is no problem. Earpiece, loudspeaker volume in call was great. NR is present as it was.
• No problem with Vibration intensity, it's as strong as in GB.
• Same incoming call UI, Answer/Reject sliders don't slide, now I am starting to believe that this is the way it is, well I will be very disappointed then, I don't like non slider Answer/Reject options, no one does I guess.
• 480x800 Wallpapers back on working on Stock TW launcher.
• Market is working fine, downloading works same as before.
• Face Unlock works
• FM Radio back and working again.
• Swype is same 3.26.92. The default KB is same QWERTZ as previous LP6.
• GPS locks is fine in GMaps. Yet to test hard GPS lock via GPS Status.
• Camera & Video Recording works, it always did.
• WiFi, Bluetooth works.. Sorry can't comment on Data/GPRS as the APN's were lost.
• Network Mode option is BACK and you can alter between networks(2G/Auto) as before.
• 1080P FLV Video played very smoothly with Stock Video player.
• 1080P YouTube videos played smoothly as well.
• Same Stock Email UI, I love it. Gray background is nice.
• Deep Sleep does work.
• Connection with PC worked as usual.
• Stock browser is great, smooth and all positive. I like it more than my gf now (Hope she ain't reading this)
• [NEW]The WiFi icon on status bar has a green/orange upload/download notification as well, same like in H+/3G, nice.
• [NEW]The update/download notification of apps are now have a big white icon in status bar.
• Same annoying and weird ICS lockscreen animation.
• Haptic feedback does work. Make sure you've enabled 'Vibrate on touch' option under /Settings/System. The touch lights do glow as well.
• New 3D sorta view in TW launcher, yes when you're switching between home screens you'll notice it but the loop feature is disabled both in home screen and app drawer, which is a big drawback for the TW users I am sure, I don't bother it as I am a Go Launcher user.
• The overscroll glow color is changed from Sky blue to GB Blue and the effect is very minimum than before.
• Settings icon is changed as it is/was in GB, don't know why am I even mentioning it.
• The touch response and smoothness of the ROM is pretty good so far. No hang or FC yet, however device did reboot once in this period of an hour.
if anybody wants to try it, remember you probably will have to re-enter your APN settings, so either make a note of your current settings or grab them of your operator's website
