Ferrari launch thread
I've never bought into that ugly car nonsense, it's there to win races why do people care if it looks like a turd.
With every change people seem to say the cars are ugly, then after a season or so completely forget about them.
Come next season everyone will be used to the cars and nothing more will be said about the nose.
Yeah, I know what you mean about the changes, especially with the 2009 spec wings that were quite a shock to everyone.
But I don't think these punched in the face noses are going to grow on anyone.
Well RBR started the whole high nose movement, so I doubt they would drop it.
We can only hope its rather more shapely than the Ferrari.
Lowered the chassis,thats not to say that is the chassis they crash tested of course.
:confused:
Why would they do that, when they ran a low nose last year and as such not affected by this step.
Not perfect camera angle, but shows no change in height.
What do you mean, assume your talking about rake. Which could just be lack of floor/rear diffuser. Seeing as the front splinter looks about the same angle. Top of the nose looks prety much same height allyhough it slops down more towards the point.
Could be floor, without having access to their CAD its hard to tell :) Id hazard a guess that the release tub does not goto testing.
Probably not, but as the floor is half the depth of last years car and they obviously not going to show floor/diffuser of. It would make sense that floor would expand to same depth as last years car, cone testing. Same with front and probably rear wing.
i dont see how pull rod is going to work at such a shallow angle. If the nose is so high, whats wrong with the normal push rod system?
Pull rod makes sense at the rear end because you want it all tightly packed, but at the front?
Lower CoG.
if they was worried about lower COG they would have lowered the nose instead of having that step. :(
They've decided, like most teams, that having a high nose is more beneficial to feed air to the floor at the rear.
Pull rod helps with the CoG, I doubt they've done it for any other reason.
i guess its just weighing up the pros and cons. Most teams see more cons with a front pull rod system though. I wonder how Ferrari will get on :D
