system spec/build ?
You will of course provide pics and a build log?:)
of course, will do.
The OcUK GeForce GTX 580 3072MB GDDR5 PCI-Express Graphics Card was not in stock and none due to come in stock either so i went back to the Asus.
I stuck with Nvidia as the drivers work well under Linux.
So will be building it all by 10am tomorrow ;-)
Cheers
I am still waiting for my stuff to come as they changed the delivery so wont be here until tomorrow now, no big deal.
However in the meantime i have been doing more research and read a few things about the stock fans in the Cooler Master CM-690 II Advanced USB3.0 Windowed Gaming Tower Case are a little noisy and people seem to be replacing them ?
is this correct ?
I am a big fan of peace and quiet especially as the machine will be on 24/7
are the stock fans no good ?
What are the better one to replace with if at all ?
I have looked at the thermalrite x-silent 140, the bequiet, and the antec truequiet ?
any opinions or recommendations on this ?
I know i should probably wait to see what the noise is like, but i dont mind spending on the fans now to get them here tomorrow if it is something i should consider ?
Cheers
The front one is harder as its a LED fan and its wired to a switch at the top of the case to turn the illumination ON/OFF.
The rear fans etc will be simply four screws and a straight replacement.
yeah it was the 140mm top fan being replaced with 2 x 140mm fans for top exhaust.
It wasnt really a major point, just a couple of mentions here and there in various posts on different forums, no one made a big deal of it, just a few mentioning the noise.
Yeah i will wait and see
cheers
so ive been looking at front panel control devices, as my buddy as a nice digital device for controlling his fans, not sure what it is as i cant get in touch with him.
Anyways i was after a internal card reader so was looking at the icybox ib-863 front 5.25@ panel.
However i saw the akasa all in one AK-ALL-02BK device which does the same as above but with fan control also and is a nice looking device.
Any opinons or recommends on this subject or these 2 devices ?
The reviews on the akasa seem to be mixed ?
Cheers
So i received the case today, decided to get some of it ready for the build tomorrow.
It comes with standoffs x 10 and standoffs-hole-fix x2 which have a protuding end
I know what the standoffs are for and i have put them into the 9 allocated ATX holes ready.
Do i need to use the standoffs-hole-fix with the protuding end anywhere ?
Cheers
These are the ones that look like they havent been finished properly and have a lip on them?
When I used this case in someones build I stuck them in the middle holes, so the "lip" went into the holes on the motherboard to help locate it.
ahh gotcha, yeah i guessed they may be for location to make screwing in easier, but hadnt seen the mobo yet so didnt know if they went into where i have put the existing standoffs or if there was additional holes for these.
I am so impatient, i wont sleep tonight cos i know everything is arriving tomorrow, i am like a kid when i know im getting new stuff...LOL
Cheers for your quick replies, i am sure i have plenty to come ;-)
i just realised that my coolermaster case is supposed to have a VGA holder ?
Is that needed to install to my grfx card tomorrow or is it a missing item i can do without ?
Cheers
You can do with out it (easily detaches) it helps support long cards/heavy cards and multiple cards.
