Either maths has changed since I was at school, or I'm using three![]()
. I did think it was a resolution problem, probably was
Is there a single card league?? I am gonna have a go at that also I think if one exists???
)Can use any card in this benchmark aslong as you follow the instructions. I personally have a single GTX 470 (hopefully still the fastest in the list once it gets updated)
@Deception, did you get hold of a second GTX 470, did notice you posted for one in the Wanted section a little while back?
. Really need one as im using an 120hz monitor and really need the FPS at the moment (although I still get 120 with settings turned down on BF3).I've redownloaded this to try my OC on but it's capped at 60FPS for me? Vsync is set to off! Any ideas?
It might be msn afterburner, the recent download has a fps limiting feature.
I have mine set to 60 fps too.
. Hopefully he will make a comeback soon enough
.TABLES UPDATED
Sorry for the lack of updates guys, been really busy with reviews lately. Congrats to pazza who takes top spot from Gibbo who never got the chance to bask in his glory. Hopefully he will make a comeback soon enough
TABLES UPDATED
Had another go with my Sapphire 5850, couldn't get any higher than 995MHz on the core or 1290MHz on the memory without the driver crashing (increased core voltage to 1250mV maximum and was starting to overheat 80C+).
In Furmark I noticed that increasing memory clock proportionate to core clock gave a good FPS increase but in Unigine it doesn't give the same performance boost (Unigine seems to prefer core clock over memory clock).
Looks like this is my limit unless I replace the stock cooler.
BIOS = Stock
Core Voltage (mV) = 1225
Core Clock (MHz) = 995
Memory Clock (MHz) = 1250
go on! crack the 1Ghz
Max voltage limit is 1.3V, and safe temps are the other side of 90c if your brave mateygo on! crack the 1Ghz
- couldn't resist another crack at it. May try for 1015MHz tomorrow but it really is time for sleep now LOL!
