Thanks Noob builder.
I will give them a call (AGAIN!!!) lol!!!
Did you managed to get a replacement?
With my C2, I can do either:
48x multi 100 bclk which gives me 4.8ghz with 1.365v (not tried IBT yet) with vt-d disabled.
OR
38x multi 125 bclk and get 4.75ghz with 1.365v (not IBT tested yet) with vt-d enabled.
Not sure which is best yet.
If I leave everything at default and let it auto level up to 4.02ghz, I have had it IBT stable at 1.250v
Nice, I can't get anywhere near that, 4.5 is a struggle on mine, but I suspect that it is the 32Gb of RAM that is holding me back.
at good price
, will be setting everything up next weekend. SR0KY but manufacture Malay on mineNice, I can't get anywhere near that, 4.5 is a struggle on mine, but I suspect that it is the 32Gb of RAM that is holding me back.
R4E, I can go to 4.8, but it will crash at some point during stabilty testing.
I need to sit down and read up on vdroop and other settings as Im not probably using all the tools I can
I use LLC on high to give 4.7, volts set manually to 1.375, but the LLC allows it to rise to 1.392 (in windows) when required, all other settings default.
i gave up trying for 4.8 (stable) when i had to raise volts to 1.40
High LLC on this board means high current. Its advised using High LLC that you actively cool VRM's or they will cause CPU throttling.
Well I finally got my C2 3930K Retailat good price
BTW. Sticking 64GB in mine![]()
woooow, id like to see info on your build with benchies![]()
, but this weekend will defiantly fill a project log ...It's like a wind tunnel in there, I think I'm good, PCH temp is highest at 35°C sometimes, That with the fan spinning at 4000+ rpm, noisey little bugger lol
I'm using the same board (although I am using the 1201 and 0013 bios from the Rog forums, as asus haven't updated there website yet with the latest bios's, and both of these helped with stability compared to 1101 that my board came with). Also my 3930k is OEM, but not sure if that really makes any odd's.
All i've done, is set the vcore to 1.370v manually, and then switched it to offset mode, and - 0.005v (so that it will drop the voltage when at idle).
I've got the multi on 47 and bclk on 100.
I also have the memory set on manual instead of XMP, and manually set 1600mhz (speed of my mem) and dram voltage to 1.500v.
LLC is set to high, and that is about it.
this persuaded me not to swap out as I dont think my next chip would be as good
