Oh, so that's what it is! I also have about 4degrees difference between the cooolest and hottest cores, I thought it was just down to architecture... My max temps are about 70C (OCed, stock were about 60C if I remember right). I run stress tests for 15 minutes though, and temps do pick up after 10+ mins on my cooler (Arctic Freezer something, wish I spent and extra fiver and got yours)
I've had up to 9 degrees difference.
I re-did it and let if got for about 15 minutes. This intelburn seems to run separate sub-200 second cycles at 100%. Between each cycle temperature drops down about 5-10 degrees for 5-10 seconds, then goes back up again. It doesn't stay at maximum temp/power for 15 solid minutes. What do you use for stress testing?
) Maybe Inteliburn drew up more watts because it was also was running tougher RAM tests? I dont know...
I haven't done my usual research into overclocking.
