Did you have 140mm fan on the bottom of the case blowing IN? wow
How's your case doing dust wise?
No? I had a 140mm fan at the top of the case blowing out. I have no intake fans at all, and never have. Now I just have one 120mm exhaust fan at the back. I blocked the opening for the side fan to get better front-->back flow through front dust filter. It is somewhat dusty, but not too bad I suppose. I have nothing to compare to though. The front filter was fairly dusty but I cleaned that about 2 weeks ago for the first time since building. Should clean it more frequently.
The usual setup (as I understand it) is to have a bottom-front 120mm blowing in and top-back/top 140/120 blowing out ...
Its been two months since I put it together.I'm going back and forth between getting the Bitfenix Raider and the Fractal Design R3.![]()
Oh, I see. Yeah, I guess if your temps are as low as yours are, you dont need intake fansThe usual setup (as I understand it) is to have a bottom-front 120mm blowing in and top-back/top 140/120 blowing out ...
Dust wise- I just wanted to share that I have either sealed or glued pieces of fine mesh over every single opening on the case (apart from vent that blows out from the case) and for the first time in my computing, insides of my PC have as close to zero dust as I can imagine they can have!Its been two months since I put it together.
I dont understand med range PC cases- expensive cases are cool (in both ways) and can look really good. But paying for med range... Why not just buy some cheap £20 Casecom 6788 that has all the features of "Big Brand" case like black painted inside (remember black body radiation Physics lessons? Black is the right colour for PC case), quick release mounts, mobo cutouts, water coolong grommets, lots of vents to fit 140 and 120 fans... And spend the rest on new sound card or something... imho
