Do we know the final GPU clocks yet for GK104? Most of what I have read indicates 700-800MHz, which seems very low for 28nm. 800MHz is not even high for the old 40nm process, where even my old GTX480 could exceed that.
It seems likely that GK104 will have lower clocks, lower memory bandwidth, plus lower transistor counts, yet it will still compete favorably against the 7970. This means NVidia's core architecture is likely superior to Tahiti's. Perhaps GCN has scaling limitations, because AMD's own 7870 comes close to the 7900 series when overclocked, even with significantly less shaders and memory bandwidth.
We will find out soon.
Lejosh is pretty spot on.
So about £420 then... Shucks. I'm not buying one till prices come down. On the bright side it does sound a little cheaper than the 7970 if the performance is indeed better.
I know you can not say much, but have you seen anything yet Gibbo ?
NDA on GTX 680 and Kepler family will be lift on 22 March at 6pm PT/9pm UTC/GMT.
http://translate.google.fr/translate...m%2F18768.html
I've seen everything there is to see in regards to presentations etc. My stock arrives beginning of next week, more than enough to go round too.
However I can't say anything that breaches NDA.
The 680 smacks of a mid-range part that is clocked to within an inch of its life to compete with the 7970 to me.
I might be wrong.
You want me to come clean your office today Gibbo? I don't mind doing it for free and you can pay me in another way....nudge nudge wink wink say no more.![]()
