Three usually take about 1-3 days to do it but can sometimes take up to a week. Restoring an ipad 2 will take under 5 minutes. Just go to settings---general----reset---erase all content and settings. No need to download ios again.
(keep in mind she has had the pad synced (backed up)to the pc in case there's any precious data she needs to keep)
These syncreon monkey's aren't too bright are they?
MG Siegler confirms in his review on TechCrunch that charging the new iPad takes “several hours” longer compared to previous generations:
Oh dear:
And it's noticeably warm to the touch.
All for the same battery life.... doh!
Yes? I guess you'd have preferred for the 10 hour battery life to have been halved to 5 hours, so you could moan about THAT instead?
Got you before your lol edit as well.
SHOCK AS LARGER CAPACITY BATTERY TAKES LONGER TO FILL!
"lol edit" - I changed "same" to "WORSE"... which it is, as has been demonstrated in reviews
No... I'd expect it to have a display that doesn't require a laptop sized battery to power. They could have made the battery smaller for a UK / European model so we aren't wasting our time with a "4G" iPad that we cannot use.
Ditto
Well what the hell were you expecting from a display that had double the amount of pixels? That the extra pixels were made from magic pixie dust that required no power to function? I'm even more baffled by your request for a smaller battery; do you actually want worse battery life?!
I haven't said smaller battery... i've said it's wrong to have a "bigger" battery that makes the device bigger and heavier. The iPad 2 is too heavy as it stands.
The battery is also larger to cope with the 4G chip... so that's no use to us.
Everyone here was bleating about how the iPad is not a gaming device and that the games aren't proper games, yet Apple have shoe-horned a power-hungry gpu in there and upgraded the screen which has crippled the battery-life. The only apps that will benefit from this is the games. The iPad 2 can run everything else perfectly fine.
I would have liked a screen that wasn't detrimental to the design and usage of the product.![]()
