- 20 Oct 2009
- Deepest, darkest Essex
i7-3960k @ 3.2Ghz
16GB RAM
120GB SSD
1TB HDD
Sapphire HD 7950 3072MB
Noctua NH-D14-2001 CPU Cooler
running Arch Linux.
u need to update your Sig bruv
i7-3960k @ 3.2Ghz
16GB RAM
120GB SSD
1TB HDD
running Arch Linux.
Done.
i7-3960k @ 3.2Ghz
16GB RAM
120GB SSD
1TB HDD
running Arch Linux.
My machine at work is this:
ubuntu 10.04 (lts)
2x quad core xeon @2ghz (i think E5405s)
24gb ram
quadro fx3800
Which is pretty quick. But my friend just got a new machine, and I am super jealous:
ubuntu 11.10
i7-3930K @3.2ghz
128gb ssd
36gb RAM
quadro fx4000
the ssd won't make that much difference as almost nothing except the OS is local, but still... I am jealous of her twelve threads...
What do you do with all that power, if you dont mind me asking/
Course not. I said 'at work' in a loose sense. I'm a PhD student in computational biochemistry.
Our workstations are only used for analysis, simulations are run on a cluster in the basement.
By simulations I am referring, usually, to molecular dynamics of receptors.
Computational drug design is the goal, by modelling and simulating things in the body at an atomic level.
Molecular dynamics is simulating how things (in my case proteins) move over time. You do this basically by represtenting atoms as balls on springs and using Newton's laws of motion, even with this simplification it is very computationally expensive. for example, I simulate 1nanosecond of time (0.000000001 seconds) per day on 8 cores. The Wikipedia page on md is quite good I think.
Not at all
I'm a contractor (mercenary or low life according to which full time staff you talk to) on the production engineering side (CNC - Computer Numerical Control Machines)....ie trying to make something that a mechanical design engineer has dreamed up on a all singing, all dancing CAD package - doh!
Worked in the automotive, marine and oil/nuclear sectors as well (a little F1 stuff). It's factory/shopfloor work
Am I the only one running Ubuntu from a USB stick?
Possibly, why would you do this for anything other than testing purposes?
