The SD card is mounted in the emmc fooder on aosp and aokp ROMs
Just flashed to hydrogenics.
How do I get the google market? It doesn't seem to be on there.
Flash Gapps which is linked below the ROM download. I had the same thing![]()
Hmm, it doesn't very happy when I try to connect it through USB
Had that problem also. It either connected as a 'Media Device' or 'Camera' Both of which did not let me copy files onto it.
To get around that I took the external SD out and put Gapps on it with a USB adapter.
You can plug it in via MTP. Make sure your PC updates its drivers and you let your phone finish media scanning. MTP lets you copy files to and from the SD card.
i'm pretty sure I've done all that. It indefinitely attempts to refresh the folders - nothing like stock.
Very frustrating
Maybe I'll give it a go later, I'm restoring back to my original ROM at the moment.
It's taking about 30-40 minutes so far to restore data, is it supposed to take that long?
[update] So I restarted my phone because it was taking too long (dangerous I know) and it booted to my old image (none of the apps installed except CWM and the basic samsung apps).
I loaded CWM and used that to restore my backup and I swear its an older version to the one I get when I press the on button and the volume up key.
Is it even possible to have two different versions like that?
