Man of Honour
- 21 Nov 2004
I'm in the you should have checked before driving off camp here. Should check your car before driving it anyway, it's common sense, i know i check mine in the mornings to make sure there is no obvious problems. Only takes 2 mins and can save a lot of grief
Well there are plenty of things that you could And probably should check that would take longer than 2 minutes. Hindsight is a wonderful thing isn't it
