- 18 May 2010
It would stop a lot of people sticking huge VTEC stickers on SOHC Hondas if they did
Maybe, I've owned both types and they're as good as each other, also its not just Honda and Toyota that have these technologies there are others
I assume in other unique feature their wheels have 'turn'.
TOLD!
Fantastic Jonny![]()
Ah right i didn't think this was a honda love in. I just threw my experience and noise in too.
And lift is what differentiates the vvti from the vvtli so it seems a natural thing to.mention..
Most tend to think VTEC is only thing in existence that controls cam profiles they tend to forget about
Mitsubishi MIVEC
BMW VANOS
Nissan NEO
Toyota VVTL-I
The two do differ in there base form though. VVT is not lift VVTL adds extra lift, this is something that VTEC has already.
VTEC is not variable phasing, iVTEC allows variable phasing.
The two final iterations that you see today have been 'added' on top.
The VVTL is a bit crude as is goes from a nice roller follower to a direct acting tappet, certainly on the 2ZZ engine. Of course VTECs have had no issue with lift bolts or the oil pumps either.
As you say now many of them are similar, although VANOS offers no lift change. I liked the Rover VVC system, variable phasing AND rotational speed.
The only thing in common with controlling 'lift' is a camshaft, hell it can even have pushrods..... lift just kicked in y0.
The 1.6 NEO VVL still holds the record for highest power output for NA per displacement doesnt it?
190BHP from an NA 1.6 IIRC, sadly JDM only
How do you find the typhoon? Is the heatsoak issue as bad as everyone says?
when its warm, and you have sat in traffic for a few minutes its noticable.
normal running and constant movement, the throttle response is still good.
I only want the tegiwa/gruppem for aesthetics really as my heart was set on one before i got the car.
I will be able to sell my typhoon on the bay for an easy £100 to put towards my newer intake.
I wouldn't suggest one in honesty, put some money towards it and get one of the proven intakes imho
or perhaps consider the hondata mod?
S2000 has more
