- 22 Mar 2009
- Cornwall
ok im lost. I have added a folder but I just get this :
Kinda, in the pic you posted on the laptop you'll see the folder on the left, but it won't be synced to the laptop by default. So you'll have to choose which folder on the laptop you want to point it to.
This is pretty much what your family will see when they get the invite and have installed Mesh... but see the warning in post #80 and test it out before doing it with real data.
oh I now see the issue here. if I delete it from 1 machine, it deletes it from both
Exactly!
So what you need to make sure is if you create the Mesh Folder - and it's empty - and they Sync it to say their Document folder, will the initial propogation delete all their files or will it sync all their files to your mesh folder on the server.
If it does that then I'd recommend they set the mesh folder up on their end first and then invite you.
But test both scenarios - I hate to see people losing data!
so now I need a sync between their mesh folder on the server and a perminant folder. so mesh will do the upload, it will then go from the mesh folder say 'temp' to a then fixed folder say 'backup' so they can then delete it from their pc (or move it) and it will still be in the 'backup' folder.
Option 1 - No if the PC crashes, and you reinstall Mesh it will effectively be a new machine with no relationship. Once you establish the relationship it will then sync everything back down to their "new" PC from your server.
Option 2 - Correct.
Option 3 - That would work, but you'd need to ensure you controlled the "temp" sync delete, and told them not to delete anything to make sure the script had run. It'd also allow you to keep an archive. But rather than give them RWA to recover, you could arrange to put the backup(s) back in the "temp" folder for them to collect.
But...if it's a new backup each time, won't it be a lot of data to transfer regularly?
Cool it should work then, and thinking about it Option 1 wouldn't allow recovery from accidental deletions whereas Option 3 would.
Still prefer Option 1 though as it's seamless to the user.
I'd still seriously consider VPN and a sync program/script on your server to pull the data to a backup folder. Seamless to the user, can be kept as a separate backup as per option 3, and no risk of deletions going in the wrong direction. I backup two remote family WHS's to my servers on a weekly basis this way.
You'd just need to install a VPN client, setup the VPN network and have credentials between the server and family PC's.
Fair enough, but I'd recommend you try Hamachi. It's as easy to setup from their perspective - just install a client on their machine and then they will be attached to your network.
Then they could just access your shares directly \\server\backup - name\ using the credentials you provide them and copy their files into the folder as and when they needed to![]()
