Nothing wrong with a decent sized epeen
I want to know when the 7990 will be here.
Please don't take the bait of those that troll or continue to deliberately cause disruption. Simply ignore them and report them either by emailing a mod or via the RTM system.
Thanks mate,some people need to pipe down,shame they cant do it without an admin giving them a warning.The guy asked a straight forward question.
If you have nothing constructive to add, then don't post! I'm armed with my Easter bonnet and baby oil, so be warned.
Yeah ive been reading around and many places seem to suggest April for the 7970 and May for 690,i hope its not as bad as the 590 was.Wow. The apocalypse seems to have happened.
OP, I'm thinking a couple of months.
kd
do you see the specs it sais my PSU is ok doesn't it, min spec is 550 W, unless that's for a non OC.
it'll be ok just way too expensive...... we'll see
I think it will be £600(599)traditional price for a dual gpu.
hang around...... it's power draw is less than my PSU..... UNLESS it's far more if OCd and i bet it is, finally; it's not worth having if you cant OC anyway, so it's kind of self-defeating
I'ts 550W max draw, no OC.... i dont know, maybe another 100 W with OC..... best PSU is maybe an OCZ 750
Dude, you're about to spend £600 on a graphics card. Stop being so cheap and get a PSU to match rather than skimping or taking unecessary risks!
its therefore the GTX 680 that's a rip off
