Don't allow unencrypted peers. Use private torrent sites.
How do you do this on utorrent ?
Force encryption, that's all I have set.
Sorry Praetorian too slow!, take a look at Invite scene if you still want one, plenty always going there.
Hmm, not sure why that is then, I'm maxing out both ways currently, try changing to random port 6881 is usually throttled anyway.
You should also disable DHT and peer exchange because IPT ban you for it.
The estimate on the checker allows for a full cabinet with maximum cross talk, you are likely to get more than 27Mbps.
thanks a lot @_)What is DHT and Why must i turn it off?
DHT must be disabled in your client; DHT can cause your stats to be recorded incorrectly and could be seen as cheating. Also disable PEX (peer exchange). This can also let outside people get access to our torrents. Anyone caught using this will be warned.
Not sure what you mean about new torrents, if you mean maxing out on them, easy.. I can pull 100MB/s+ on my seedbox from anything on there plenty of speed going.
Nevermind it was just the torrent I had selected
Just got full speed through one of them
FU BT![]()
I see green cabs popping up everywhere now. I heard next year BT are going to trial 300 meg down.
