Grease!
16 Feb 2009
I'm decorating the kitchen in my flat with the help of mr-white and above the work tops is a layer of grease which has built up for a number of years.. Flash kitchen just isn't cutting through the stuff. Can anyone recommend something stronger which will cut through the grease.
29 Sep 2011
Monkey Island
It is a good cleaner. Good for stubborn stuff like glue/grease.
Don't see the point in using something that leaves a residue that will then have to be cleaned off afterwards.
Not only that but it will seep into the surface/crevices and the wd40 smell will remain.
Lets put it this way, you don't use something like that that you will be painting over, it's, just, silly.
29 Sep 2011
Monkey Island
Wet and dry sandpaper for the top of the cupboards then, (use it wet) and use an old towel to keep taking the excess off. (tear towel into bits so you can keep using clean bits instead of wiping grease around rather than off)
As for the metal start with a plastic scraper, then finish off with whatever you have been using or like the above poster says, scolding hot water and bleach is the simple effective and cheap final method.
VoG
VoG
20 Jan 2004
Nottingham
Sugar Soap, might take a couple of goes if the grease is really mega thick & caked on, but ide be surprised if it did tbh.
Oh, & you want the powdered variety, not the pre mixed solution.
