Would a new CPU give me a good increase?
12 Dec 2005
Currently using an E6750 and since I'm getting back into gaming I'm thinking of upgrading.
If I was to upgrade to an AMD Phenom II Quad would I get a noticeable performance increase over my E6750?
Cheers
I just want to get some better performance, for example in TF2 I play on mostly max settings @ 1920X1080 and when there's lots of action on screen my FPS dips below 30fps.
My specs are:
E6750 2.66GHz
4GB DDR2
5770 1GB
Would a better graphics card be an option? Should I buy a cooler for my E6750 and overclock it?
Cheers
My specs are:
E6750 2.66GHz
4GB DDR2
5770 1GB
Cheers
Overclock it. I emailed Robin Walker about this back in 2009:
Robin Walker said:
There are a variety of reasons, actually. Some of them are:
- Our engine is designed to run on as wide a range of computers as possible. Many of the machines sold today have fast CPUs, and very bad GPUs.
- Our character & facial animation system is all done on the CPU, because GPUs haven't had the functionality required to do it until very recently.
- TF2's character animations are more detailed than most other games. More CPU is spent on the character animation setup than anywhere else in the rendering pipeline.
- TF2 is a more complex simulation problem than our other games. Players create more separate entities (projectiles/sentryguns/etc) that require simulation than CS or DoD, for instance.
Hope that helps.
Robin.
The multi-core rendering option is 'bodged on' so to speak, it was added after the release of the game and when multi-core CPUs became popular. This means that in TF2, dual vs quad is a bit of a moot argument, for most it only makes use of 2 cores properly.
This. Also for general gaming performance you'd probably benefit more from a new GPU if you overclock that dual core. Many games don't make use of four cores that effectively and that CPU isn't going to bottleneck (for example) a 7850 much if at all.
I think I may be able to get a 3.2GHz Overclock if I push it with a good cooler. Do you think that would give a visible performance increase from 2.66GHz?
And I really would be able to run a 7850 along side a e6750?
I have a Corsair CX430W. Nope my mobo isn't a crossfire one and it doesn't really overclock that well however I am confident I could get atleast 3.00GHz from the E6750.
I'm really unsure what to do. Should I use my AM2/3 Mobo and buy a CPU for it?
Would appreciate any opinions.
TF2 should not dip below 60fps with a 5770. It was my card you bought after all so I can say from personal experience (I'm running a phenom 2 955 3.2ghz). Even with my 8800gt and [email protected] I got great performance so i'd certainly attempt an overclock.
Personally I would try to get a phenom II x4 for your AMD motherboard as you can get them for around £50 second hand, cheaper if you get an athlon x4.
Personally I would try to get a quad core for your AMD motherboard as you can get them for around £50 second hand.
Yeah, I think it's the CPU letting me down to be honest. It gets a real slow down when it's in the middle of a 32 player map for example.
I don't have the orange object anymore that's around the CPU socket, do I still need that or will a normal heatsink just fit in place of it?
Cheers
