Or just get the One X surely?
).The only downsides to the One S for me is that u can't remove the battery & the lack of MicroSD
I've had my spica for 24months and had to replace the battery after 18months
Also I've had to pull the battery a few times on the spica when it has stopped responding
Other than that I think the One S would be ok for me.
(i5700 model) and lets just say the difference is hugeeeeeeeeeeeeeeeee!
I'm also fully expecting the One X to match the S for smoothness and speed when HTC sort the software out. There's no way you should see a difference in anything other than benchmarks.
S3? Just got a bit confusing lol, or do you mean One S?![]()
It will probably be a mix of the GS 2 and GN.No, I mean the One S. On the X there are some slight bits of stutter/animation lag in places and the S doesn't have that (so much, apparently). It's only something I notice because I'm extremely fussy, most people wouldn't.
It's going to be down to software optimisation rather than a lack of power though, as both have plenty. HTC have got a few updates and fixes they need to release so it will improve with those.
I think I will stick with the X and just hope that the updates will improve battery life like you say![]()
Have you held both of the phones? Do you know how big the One X is? It's quite different to hold than a GS2 / Sensation.
The battery life is pretty poor when compared to the S, I can easily get a min. 4 hours of on screen time at about 50% brightness with medium to heavy usage, the X seems to only get about 2 and a half, 3 at most from what I have seen so far (it should improve with an update apparently but I can't see it being much of an improvement) but that is to be expected considering the screen.
As for "better processor".........the S has the better processor, just because the X has more cores doesn't mean it is better![]()
Hmmmm ... I think I would still rather have a higher spec phone, like the HD screen, NFC etc, rather than better battery life, I'm sure that updates will improve it a bit and changing power settings / backlight settings will help too
When it comes to general usage, the One X should still at least last one day right? Just light usage, as if I was at work or college, so the a few text messages, checking emails, facebook, twitter and maybe a phone call or two??
Can you confirm this Robbo? How long does your One X battery last with the above sort of usage? (I willl post this in the One X thread so you can reply there instead if you want)
(30-50% is perfectly fine for indoors or/and a dull day and 70+% for a bright sunny day)
The One XL seems to be getting 4-5 hours 'screen on' time, that's with LTE too...
Yeah it comes down to personal preference in the end
The main advantages the X has over the S is NFC, more internal storage and the screen.
You should get a day out of the mobile with that usage providing you get good signal and don't set the screen to a ridiculous brightness(30-50% is perfectly fine for indoors or/and a dull day and 70+% for a bright sunny day)
Updates should improve it, but don't be expecting an additional 1-2 hours or greater for on screen time
And also connect to wifi when available instead of staying on the mobile network connection and if you don't need the internet, disable all wifi and mobile network connection completely![]()
Yeah think I'm gonna go with the One X as like you say it is fine as long as you don't have stupid screen brightness and unnecessary apps running 24/7 etc.
I'm sure there must be apps (similar to ones you can get for BB) that automatically turn off wifi when it's not in use and things like that?
and again that will just use resources running in the background.4-5 hours is a reasonable amount like Robbo said considering all the features of the phone
I will also set it so that the backlight goes out quite quickly after I'm done using it so that should help too
I think I'm gonna get the X, like I said, if I don't then I will always regret not getting it just for the battery![]()
Just to let you know in advance, you don't need to kill apps now
http://geekfor.me/faq/you-shouldnt-be-using-a-task-killer-with-android/
Yup there are, it is also built into the phone stock software where it disables after 10 min of inactivity, however, you are better of doing this yourself as things will be connecting to the internet in the background every now and then e.g. weather to update, emails to "push" etc. etc. and so if the wifi keeps switching on and off, obviously that will use more power than just leaving it on.
This app automatically does things for you:
https://play.google.com/store/apps/...MsIm5ldC5kaW5nbGlzY2guYW5kcm9pZC50YXNrZXJtIl0.
But it only takes a matter of seconds to do this stuff yourselfand again that will just use resources running in the background.
Also just in case you aren't aware
The One XL is not the same as the X, the one XL has pretty much the same internals as the S but in the body of the X with the screen of the X and the same battery as the X.
So it appears that the main difference in battery life could be largely down to the krait processor that is used in the XL and S as it is more power efficient than the quad.
And lastly you can set the screen to turn off after a certain time but you can do this yourself once you are done using the mobile by just hitting the lock/power button and the screen will turn off immediately whilst being locked as well
EDIT:
Also, don't use automatic screen brightness, it makes the battery life worse!
And switchpro is a great app/widget.
Yeah I held it in the O2 shop yesterday
p). No doubt the camera will be better, but I don't take many pictures so I should try and avoid getting it.Thanks for all these tips and links etc
I was not actually aware that a One XL exists, I thought it was just sarge joking as the One X is a big phone lol
I never clicked 'show all products' on the HTC website so didn't see it, ooops
I just looked at it but it doesn't have NFC, HD screen, or 1080p HD video recording so I think I will still stick with the One X, thanks for making me aware that it exists though as I genuinely didn't know lol
EDIT: I assume you are talking about the Sensation XL?
