- 22 Mar 2009
not all of them thought, most cpu only do 4.4GHz and cannot gone above that depend on board and chip.4.6ghz on a £25 cooler with SB is fairly easy. I wouldn't be so sure with IB.
Also Bulldog IB safe temps are anything below 85C...
Off Topic: is the Antec Kuhler 920, genuinely a top end cooler?
I use a "proper" water cooling loop, with 2 rads and a reservoir (currently using a Swiftech waterblock) - how would the Kuhler compare? I'd have thought that in the World of water cooling, Kuhler woudl be right at the very bottom. Correct...or not?
Damn it Stulid you haz ?!
Anyway FWIW if this chip comes in at below £200inc then it takes the bang per buck crown away from the 2500K
Agree or Disagree ?
So a 3570K for £199 would be better value than a 2500K for £160? I don't think so.
Factored in the new CPU price premium ... take your troll face off dude
It should drop to £180 or close to 2500k prices as it ultimately replaces it
It will most likely come in at a tenner extra over the price of the 2500K it is replacing. As the 2500K was the best bang for buck at this price then it figures that the 3570K will be too.
time for an upgrade with quadruple times the goodness![]()
Holy moly, the temps are shocking with Intel burntest. I wont be doing that again.
LOL
