- 31 Jan 2012
Im using usb hubs now to power the adapters and still the same.
in 2d 120hz is great.
Quick update for you Daz
Just got the leads and had a quick test.
I hadn't set eyefinity yet but when I first booted with the Startech adapters plugged in I got the error msg and the center screen was black.
But in Windows "Screen Resolution" I noticed one of my monitors was just set at "Generic PNP" while the other two had "SyncMaster SA700_S23A700D (Digital)"
So I installed the Samsung Monitor Driver that came with the disc onto that monitor and I've not had the error msg again and eyefinity started all at 120Hz fine touch wood. Hopefully this might help.
EDIT* It didn't I just got that error myself when trying 120Hz eyfinity again
However I still get a DirectStereo3D error when starting Tridef3D and setting "AMD" "AMDHD3D Technology" ( which is FrameSequential the best 3D mode on these monitors) in the Tridef Control Panel
I still can only start Tridef3D in "Standard Display Types" "Line Interlaced" (which then means I have to change everything, monitors and Tridef to Above Below when in a game)
When games start I STILL only have two monitors showing 3D! (I still need to contact Maxlive from above about how he connected to all three)
Also the far left monitor is showing text in a very weird way like thin and hardly readable.
All in all I feel Ive just wasted over £500 and should have just stuck with the one monitor, which was great and upgraded my mobo so I can go Crossfire then getting the monitors in the future when AMD and Samsung sort this out
I wanted 3D in Eyefinity.
I was told that these adapters should sort it but they didn't so I might look into returning two monitors and the adapters if I cant get this running.
I'm scared to try new ATI drivers after the trouble I had the other day but am going to try a few things and will report back.
