You could also watercool those cards. Once watercooled they run like a dream and can be almost silent![]()
Stop posting on ocuk when you are on holiday please.
What case have you got? Ive recently found, a case with poor intake will up gpu temps.
Montage clip I made from Beta til now, let me know what you think.
Nice, but ill say this. On pc, the beta and even the alpha were a lot better than what were playing now.Montage clip I made from Beta til now, let me know what you think.
It plays better on console with only 24 players.
Every game i've ever played on that map has gone one of two ways
1. Stalemate
2. the other team gets spawn trapped and spawn raped.
I've been spawn trapped almost as many times on the RU team as i have the US team which leads me to believe that the strength of your team is more important.
To be honest, i expect with 64 players it would just end up in stalemate all the time !
The game was nigh on perfect till the back to karkand dlc release. After that it has went downhill very quickly. They added in this gimmicky network slider thing, what an utter waste. It does nothing whatsoever. A total waste of time that could have been used in any other aspect of the game. The hit reg is the worst ive ever seen in a pc fps, and ive played quite a few. Heck even dice's own moh 2010 is better. It's a bit of a marmite game, but the reg is perfect and it's a lot better looking than bf3, less cluttered looking. It took 3rd party fxaa developers to improve the look of bf3.All I know is in the beta my hit registry was a lot better.
That was an option Kiwi, but ill be getting shot of both of them shortly. Either a single gtx 680 or a pair of gtx 670's in sli, depending of course on price. The 470's are great overclockers, mine are factory oc'd gigabytes, 630mhz core. Though i run them at 750mhz on stock volts of 0.987, theyre bench and game stable at 800mhz on 1.012v but stuck with stock coolers. Hence theyll be gone soon.
What I don't like about the visuals is there's so much that hampers your vision, from RDS, flashlight to dust, smoke and even the sun!
I only got the game yesterday but I won't play it much more, as soon as Diablo comes out I will most likely never play it again, mostly due to the hit registry and lag compensation. I'm just glad I only paid £12 for it.
yeah you and many others play daily, no lag complaints at all
except maybe one of two huge spikes when it went to 800 ping, but that's over the life of the game, not per session.Yep, ''An unknown error has occured, Please restart this POS program and hope it works again''
I used to run my system in a high end Lian Li case, excellent airflow. I was able to run my gtx 470's on a custom fan profile, no frame limit set. Now using a bitfenix shinobi xl case, terrible airflow. Have to run a frame limiter in game to keep temps down. Old and new case below.
I might go back to the Lian Li, as it's a much better case for cooling, shame it's bare aluminium inside.
I'm not running as much hot hardware as you, but Ive found the cooling of my Shinobi case to be excellent.
