Would it benefit me to change to '(standard display types)', 'Direct 3D Stereo (120Hz)' like yours?
Not got it myself, can't try it out.
If it has a dual bios switch on it, get RBE and manually change the voltage in the bios?
My control panel by default is set to
Manufacturer: (automatic detection)
Model: AMD HD3D or Side By Side
Version 6
ATI Radeon HD 5800 Series
Current: 1920 x 1080 at 120.0Hz
Preferred: Any resolution
I only changed it trying to launch Transformers, it worked that way, where as getting tridef launch errors using the AMD settings.
Give it a try, you can always change it back.
Well for starters I think Active is better purely from a resolution point of view. But, I think the main thing is that moving to active is hard at first because your eyes aren't used to it. After a while your eyes wil adjust and you shouldn't be getting any headaches or anything.
But, there is a also a trick out there to solve crosstalk and flickering issues. You cover most of the sensor on the glasses with black electrical tape. It cuts down on sync issues and flicker so should reduce eye pain as well. I would give it a try if I was you.
I think with this monitor and if you have an AMD card you are best to stick with TRidef rather than go for nvidia 3d vision. You should be able to get frame sequential working which is much better than side by side.
You're using side by side for 3D at the moment?
I seem to be yeah. Am I doing it wrong?![]()
Rome Total War.
It has its own .exe but I can't launch the .exe as I get a "can't find steam error"
Needs to be launched through Steam.
Nvidia vision was sooooo much easier to use when I was using anagylph, passive would have been exactly the same for ease too.
For 3D Mode I just use direct3dstereo120HZ, I assume that's correct?
well you can try this, start tridef and select add a game as normal and point it to steam.exe, then select generic profile.
Now in the command line arguments section put
-applaunch 4760
Not sure it will work but give it a go.
Just got these monitors yesterday and love them, really great picture. I'm having an issue with a 3 way setup and posted the issue in the graphics card section but will add here too in case anyone can shed some light on this:
I have one MSI 7850 Frozr III and 3 x Samsung S23A700D in a 3 way setup @120Hz. I'm using catalyst drivers 12.3 (12.4 was even worse).
I have two monitors connected via startech mini display port active adapters and one monitor connected on the dual dvi. Unfortunately the dual dvi screen is tearing and it doesn't matter how I switch the cabling round, for the monitors, the monitor connected via dual dvi always does this. It's not unusable but it's one of those things, that you know it's there, even in windows and just gets annoying. After looking around I found other people having this issue and it seems to be the only solution is to have three connectors all the same type. This seems really odd though when most cards, even the 680s, have 2 of one type of connector and 1 of the other types.
Looking around at upgrades, some of the bespoke 7970's have 4 or more mini display ports but that means buying another active converter or maybe just going the whole hog for a 690 which has 3xdual dvi. Has anyone else had issues with this?
How'd you get Steam games to work with Tridef?
I'm struggling![]()
The switch only does something with the DVI to allow me to do 120HZ.
RBE doesn't work with 7970's yet.
Seems I'm stuck for a while.
so it turns into 980x1080.Good point, will do.
Thanks for the tips. Yep, I'm prepared to persevere, you may be right about adjusting to them.
Where exactly are the sensors that need covering with tape?
As far as frame sequential, I see it listed in the monitors 3D mode settings (Off, 2D>3D, Frame Sequential,Top-Bottom, Side-by-Side) but I thought all those settings were nothing to do with Tridef? Do I need to set it to Frame Sequential then from the monitor or should I find it somewhere else in the Tridef software?
I just read it on a few different forums about active glasses. it can only be one of two spots where the battery goes or where the power switch is. You're only getting 980x1080.
The reason why I got rid of my GTX680
And Rome Total War won't work because it's DX8.
Nvidia 3D Vision is so superior to this it's insane, and they know it =/.
So very much wish I'd gone passive with the 680, too late now.
?Side by side is obviously going to make the width smaller because the screen is split into twoso it turns into 980x1080.
I'm honestly not sure about that. It completely fills my screen like 1920 x 1080 2D, only it's in 3D.
Those screenshots aren't Side by Side as far as I can tell?
They look fine to me.
I just use Direct 3D 120HZ stereo thing.
And my Rome Total War issues are a lack of compatibility with the older DX8.
Yea I see what you mean I only tried sbs once on crysis 2 and didn't think there was anything wrong with it though.
Have you checked the Tridef forums for a Rome profile? Sometimes users upload ones that fix things the Tridef ones cant?
Also you can change Tridef to Anaglyph in the Control Panel if you ever want to use that.
I'm not sure then, but SBS definitely halfed my width on my 680.Well 0001 was taken side by side last night, the rest just now in 'Direct 3D Stereo 120Hz'. Either way, nothing changed for me, both look great.
