Location, cost and weather at a guess.
Yep. European, sunny, and traditionally used for testing.
It's a shame they don't go elsewhere, there are some great tracks about.
 I guess some people will have egg on their face now.
 I guess some people will have egg on their face now.What is a monkey seat?
McLaren tested a higher nose on one of the days apparently.
McLaren can adjust the brake ducts?
In addition to the nose could still see something interesting in Mugello. Both Paffett and Turvey came during their long runs every now and again briefly in the box, parked parallel to the garage and drove to a few seconds further back. During the brief stops were not as commonly changed tires or temperatures measured. They could see only two mechanics here who feigned on both sides of the airbox with a little crank spins. The only question is what?
Without a glance at the Carbon Dress we have no definitive answer - but a hot suspect: Even before the Mugello test there were already some rumors that McLaren is said to have developed a new revolutionary ventilation of the brakes, during a race can be adjusted. Initially there was speculation that the system will only work on the rear axle. The competition but now believed that it is both front and back tested.
Temperature regulation for tires
The benefit is easily explained: The system is not about the temperature of the brakes but the heat output can be controlled from inside the rim of the tire. The first Grand Prix of the year have shown there: Who can race Sunday to respond to temperature fluctuations, has a big advantage. The new Pirelli rubber of the 2012 vintage will only work in a small window.
It would be a real coup if the engineers had found a way out of Woking, adjust the temperature in the tires during the race. Since it is the brake ducts to aerodynamic parts, the driver from the cockpit itself is nothing to adjust active. If there is no other trick would have to make the mechanics during a pit stop, the necessary settings.
At the pit stop to get but not ran directly to the brakes without taking the tire change in the length. There must be another solution be found. Have the necessary screws will therefore be moving into the central part of the car? Perhaps we are in Barcelona a little smarter. Auto Motor und Sport is tuned but definitely on topic.
	what developments did the teams bring anyway?
Mercedes really do seem to be getting their act together. Good to see.
