What is every one achieving with this ram?
Im planning on buying a 3570k.
If I bought this ram, entered the bios set the ram too:
- 2400MHz (11-11-11-28 1N) @ 1.50v
Does it affect the way the cpu gets overclocked?
As in would I just go about increasin the speed and the vcore, until I reach max safe heat or voltage? Leave LLC and other things on auto I presume?
And what are these values?
None of the CPU I have take a hit on overclocking at 2400mhz RAM speed. Each IMC is different though. Its when you get above 2850mhz that you need more Vcore to actually attain high CPU and RAM clocks simultaneously. I achieved 10-12-12-24 1T straight up on these sticks in MVG. Then went 11-13-13-25 1T for 2600mhz. Its not as easy as plug and play though with most systems your gonna need to tweak the settings abit. Which board you getting??
AUTO settings for things like LLC are ultimately probably not going to be good enough, you will need to set these and test accordingly.
this RAM is addictive!
