New Build Gainward GTX 680 Problems :( HELP!
The make and model of your ram will have timings like mine are 9-9-9-24 and rated at 1.5V.
This you need to check and make sure it is the same in the BIOS.
Just installed cpu-z and here is my ram settings by the looks.
Does this look right?
To me that's incorrect?
RAM : 4096 MB DDR3 Single Channel
RAM Speed : 800.5 MHz (1:12) @ 11-11-11-28
Slot 1 : 4096MB (12800)
Slot 1 Manufacturer : G.Skill
Is how i see it
Yep looks fine to me. Add another stick of ram in make sure it is set for 1 & 3 or 2 & 4 (not next to each other) and see how that runs.
that TDR regedit is one I've used before. Doesn't work in the majority of cases, and is dodgy according to most people.
http://forums.overclockers.co.uk/showthread.php?t=18393075
in fact it was you gregster who said it was a workaround an underlying problem :) (only just spotted that)
And again I said the same thing here bud ;) It is just a plaster but I wouldn't consider it a bad thing. I used it long enough and had no probs from it (I still had crashes though very occasionaly).
ive manually set timings to 9-9-9-24 to see any diff, also stuck 2 sticks in 1 / 3 at the moment.
So you think it's purely the GPU at fault ?
I firmly believe it is a volt thing. In so many of these cases it is either drivers or lack of volts.
The display driver has stopped responding and has recovered is the most annoying ever as I have seen so many people with this problem and does not matter if AMD/NVIDIA they both get it. I used to think it was Windows 7 and Vista coding, as these were the only 2 operating systems it affected.
Now after more knowledge on this error, It normally boils down to 2 things...Volts or drivers.
Let me know how you get on with the 2 sticks of ram in please.
