Come to Glentress then I can squirt over your rear shock![]()
I'm not sure that's the kind of 'fork juice' he was looking for!
the bike is here, i've got a problem though. the reverb hose has come away from the lever and liquid from the lever has come out, how do i go about fixing this?
i'll gets some pics up as soon as possible.
**** easy to fix.
There's plenty of youtube videos showing you how to do replace the Reverb hose/bleeding it etc. If there's no damage you could just put it back in, but you'll need to bleed it.
SHOW US THE BIKE
WHOOOAAA, sicker than gay aids!
You need to order a new barb then im afraid and just replace/bleed it.
I missed the bump when you posted pics - the bike looks incredible!
All shock pumps should create a seal when you unscrew them, I would try a different one if you can.
I use sram too and ironically have found that the 10speed x9 stuff on my FS bike doesn't shift half as nicely as the 9speed x0 stuff on my hardtail, the 9 speed has a reassuring 'clunk' when you shift whereas the 10speed feels a bit weaker especially when downshifting.
