Guys I was able to flash my Powercolor 7850 to an Asus and my voltage is now unlocked.
My card is stable at 1260mhz on the core and 5600mhz on the memory. Is that good? I'm at 1.3v.
Flashing is still risky but I did it and everything works great.
I used atiflash.exe from a dos usb key drive.
I typed:
atiflash -p -f 0 asus.rom
Just replace "asus.rom" with whatever rom you're using.
Remember this is risky if you're doing it! It worked for me but it might not work for you!
What settings were stable at before the flash? Does this mean you're able to clock higher?
) as to how to do this flash? is it possible to do it in windows like unlocking the extra shaders in bios of the 6950 was done? I'll certainly give this a go if it appears easy enough
