*** The Official Diablo III Thread ***
Status
Not open for further replies.
That sounds good, erm... I'm level 20 with 92 intellect? :confused::o
Wow really your damage must be quite low seeing as intellect seems to make a huuuuge difference for the witch doctor my intellect tooltip says that 320 int is increasing my damage by 320% :o
Im only lvl 24 how can mine be so much higher lol? :)
Loving the game so far, just got to level 10 with my Monk! :D
My only gripe (note, not complaint!) is that I like to uncover every inch of a given map and there are just so many off-shoots it is difficult to remember what you have and haven't covered! :p
Also, I'm basically equipping the highest dps weapons that I come across - is this "the way of the monk"? or should I be concentrating on certain types of combat?
I've just joined a party with two friends and since then when I go back to my single player I have been put back to a previous mission?
Any ideas anyone :-(
Ohh my God, I went to Options-Account-Server Region Selection and apparently I have been playing on American servers so I have to start again on european, guys try and do this aswell it's american servers that have gone down for maintanence not european.
OMG this happened to me also. Why can't the EU client default to EU servers :(
Oh well.
It will run at 60 fps until the hiccup occurs, then it drops to ~57 with a noticeable lag in gameplay, then right back to 60 until the next hiccup occurs. Changing graphics settings does nothing to improve from high to low settings, windowed, fullscreen, AA, etc.
You learn something every day! You'll feel like a god when you use an up to date weapon then :D nearly all your attack abilities go off weapon damage, even your pets.
Jesus! How much easier is this game now? Before I was having to dodge and move around a lot, now I can just wade in. Doh!
Thanks for the info and helping a lvl 20 newb!:o
If you press 'M' while running about it brings up a map clearly showing which paths you haven't uncovered yet and which areas you have revealed.
Must be to do with your magic armor items?
I thought I was equipping the good stuff (all yellow thus far).
Iv you press 'M' while running about it brings up a map clearly showing which paths you haven't uncovered yet and which areas you have revealed.
The TAB key also brings up the map, I find that easier as it's next to action buttons. :)
Does anyone else get this weird problem where the game will suddenly feel like it's frame skipping -- like it's slowed down, and it goes away when you alt tab and tab back in again? It's not the stutter problem -- it's like it's throttling down the CPU or GPU, but I've used CPU-Z and GPU-Z and there is no throttling happening at all, nor is the temperature high.
Hmmm.
Doesn't happen often, but it's strange.
You'll find that a lot of the yellow items are weak on +stats but have more +secondary stats like gold-finding and after-kill effects.
They're pretty much useless IMO as +intellect is all you want on a WD or Wizard.
o_O Was pretty sure that big siege guy from vids from ages ago was last boss in first act .... aparently it isnt :S.
Was happy to see our old friend instead tho :-).
Now sleep, work and tomorrow finishing act2 after work, shame I only get 3hr or so to play a day at best :S.
Status
